The Six Speed Swap Thread
1 reading
258K views 585 replies 93 participants last post by  sharpman993
#1 · (Edited by Moderator)
I figured I'd start this thread to catalog the different six speed swaps and configurations available to the GC8. I'll list a few common configurations and parts lists.
To answer the usual newbie question: Any EJ motor (any Impreza motor) will bolt up to any EJ transmission, and the six speed is no exception.
1. Full STi driveline swap
STi 6 speed clutch
STi 6 speed flywheel
STi 6 speed pressure plate
STi 6 speed clutch slave cylinder
STi 6 speed transmission
STi 6 speed transmission mount
STi 6 speed shift linkage
STi 6 speed drive shaft
STi front axles
STi front hubs
STi R180 rear differential (final drive matching that of the transmission)
STi R180 rear axles
STi R180 rear hubs
STi front and rear Brembos
STi Brembo rotors front and rear
(If using '05-'07 hubs, custom coil overs are recommended to maintain proper suspension geometry to mate from the 5x114.3 bolt pattern to the GC top hat bolt patterns. These custom coil overs would be GC top hats with a '05-'07 STI bottom sleeve to mount to the hub)
2. Version 6 style driveline swap (maintains 5x100 bolt pattern, allows for use of 16" wheels over 4/2 pot brakes while keeping R180)
STi 6 speed clutch
STi 6 speed transmission*
Stock GC front axles
Stock GC front hubs
STi R180 rear axles
2004 STi R180 rear hubs
STi / WRX 4/2 pot brake calipers
WRX 4 pot front brake rotors
DBA Group N rear gravel rotors or later model JDM GC8 R180 2 pot brake rotors
3. STi/WRX hybrid driveline swap (cheaper than the previous two setups, many WRX drivers choose this because they already have the matching rear end)
STi 6 speed clutch
Impreza 4EAT automatic transmission drive shaft
Stock GC8 front axles
Stock GC8 front hubs
WRX R160 rear differential (final drive matching that of the transmission)
Stock GC R160 rear axles
Stock GC R160 rear hubs
Stock GC brake calipers
Stock GC front and rear brake rotors
4. STi/WRX hybrid axle swap (cheaper than the previous three setups, you get the stronger R180, but the weak link is the axles)
STi 6 speed clutch
Stock GC front hubs
STi R180 rear axles
Stock GC R160 rear axles - Use the four rear axles and a custom race by suberdave of NASIOC to make a hybrid axle to use your stock hubs
*Note: Depending on the transmission you are swapping in, you may need to purchase axle stubs, seals, and circlips to mate your female axles to your female transmission. This essentially converts your '05-'07 female transmission to a male transmission that will mate to GC female front axles. Additionally, it is possible to obtain an '04 STi transmission that has had these parts removed. The following part numbers are here:
Early 2004 Axle Seal Part Numbers (to be used with axle stubs / female axles):
Left: 806730041
Right: 806730042
Circlips (You need two of these): 805329010
Axle Stubs (You need two of these): 38415AA110
Clutch/Flywheel/Pressure Plate/Slave cylinder notes:
It is possible to use an '02-05 WRX pull style slave cylinder, clutch, flywheel, and pressure plate with a six speed swap, but since the RS is a push style system, you would have to source these parts anyway, as none of it could be reused.
Final Drives:
'02-'05 USDM WRX 5MT: 3.54
'04-'05 USDM STI 6MT: 3.90
'06-'07 USDM STI 6MT: 3.54
Based on these final drives, it is possible to use an '02-'05 WRX 3.54 final drive R160 rear differential with an '06-'07 STI 3.54 final drive 6MT transmission. Other combinations of trans and rear diff will require the ring and pinion on the rear differential to be swapped to the proper final drive.
Six speed transmission codes and details (this helps immensely when picking a transmission based on features):
Master 6 Speed Transmission Decoder Ring - NASIOC
'08+ STI 6 speed transmissions:
08+ STI transmissions are slightly different to swap into an older model (GD's included) because they don't have vehicle speed sensors for the older ECU's and speedometers, and the newer ECU's and speedometers instead rely on the CANBUS system to relay a speed signal from the ABS sensors. To remedy this, you can use one of the two solutions:
VSSPro: A device built to read the ABS ring sensors and convert that to a speedo signal found here.
Earlier 6MT bell housing swap:
You need the following parts to swap to a pre-08 6MT bell housing that includes a VSS (thanks to seangfy).
32001AA210 GASKET & SEAL KIT-MANUAL TRANSMISSION FIG-111 3232001 1
30400AA040 HOUSING ASSEMBLY-CLUTCH FIG-112 3030400 1
32024AA011 GAUGE ASSEMBLY-OIL LEVEL FIG-112 3232024 1
806912140 O RING FIG-112 G9G9121 1
031512000 SNAP RING-OUTER FIG-117 1
32714AA360 GEAR-SPEEDOMETER DRIVEN FIG-117 3232714 1
32713AA050 SHAFT-SPEEDOMETER FIG-117 3232713 1
803012060 WASHER FIG-117 D0D0120 1
805012020 SNAP RING-OUTER FIG-117 F0F0120 1
806712100 OIL SEAL FIG-117 G7G7121 1
32715AA050 GEAR-SPEEDOMETER DRIVE FIG-190 3232715 1
38415AA110 SHAFT-AXLE DRIVE FIG-190 3838415 2
805329010 CIRCLIP-INNER FIG-190 F3F3290 2
806730042 OIL SEAL FIG-190 G7G7300 1
806730041 OIL SEAL FIG-190 G7G7300 1
I believe that's about it, I'll add information I as I deem it to be necessary.
#531 ·
I reused the GC crossmember, mustache bar and trailing arms in my 6mt swap. Everything else was 04 STI (hubs, diff, axles) or GG WRX wagon (06 Saabaru Aero to be precise), such as lateral links. Wheels are as centered as with the stock equipment.
When I did a lot of suspension changes to my 98 OBS (suspension, rear disc swap, sways, etc), the wheels visually pulled forward like I think you're talking about. This typically happens when you lift an OBS. The solution in that case is Gen 1 outback trailing arms, they are slightly longer and make the wheels almost centered again.
#532 ·
Ah, I think I misunderstood the question. Is this about the wheels appearing centered from the side profile, or poking out too far from the rear profile? If it's about the wheels not appearing centered from the side profile, it's likely the use of the SG Forester STI trailing arms.
#533 ·
^You got to it before me, that was the only thing I could think of that would push the wheels further back.
Haven't posted in a while but this thread was a huge help. I'm still running the same setup I put in 5 years ago without any problems. 05 usdm 6spd, wrx wagon driveshaft, 3.9 r160, rs front axles, wrx wagon rear axles and rs hubs/spindles on all corners.
No plans to really change anything in the drivetrain but will be switching from H6 rear brakes to 05 LGT rears soon.
#547 ·
Ok apologies for being a newb about this, because transmissions aren't my strongest area of knowledge, but from reading this thread it sounds like option 2 is my best bet?
I basically want to have a 6 speed dccd set up that will fit a non wide body coupe (I don't want to flare fenders or go wide body), and also have the flexibility to use the 4/2 calipers (my car is for spirited driving and daily driving, probably don't need brembos for that).
And it sounds like if I do the ej207 jdm swap, if I have a usdm transmission set up I should still be ok (unless I'm missing something).
So for me, I should start sourcing for option 2? So basically look at junk yards for 04 STIs with healthy undercarriages and raid them for the specific parts listed in this thread?
#548 ·
If you are doing the ej207 swap just get one that includes the matching 6 speed and I would get the brembos too. You quickly enter a gray area when you mix and match parts. It works, but information becomes questionable and repairs down the road get difficult when you are trying to remember what year and model a part came from.
Sent from my Pixel 3 XL using Tapatalk
#551 ·
For the transmission back, the JDM parts (outside of gear ratios) are interchangeable with the USDM equivalents.
As far as the track width of the car, that's determined by the suspension, not the drivetrain. Within a JDM kit, you could find a '01-03 5x100 set so that you got the Brembos and didn't have to worry about your struts bolting in. Newer than that would be 5x114.3.
The parts that determine your track width are:
Front: control arms
Rear: lateral links
People run wider axles from the GD in the GC track, and I'm doing it in the rear of one of my cars. I've not tried it in the front, but I've not had any issue with the rears for years.
#556 ·
Thanks for confirming, I know people have run the longer sti axles on narrow track width with no issues, just thought better safe than sorry if possible.
On another note, GD knuckles are getting way too $$ these days, just bought a set of front VA ones to try, couldn’t find any concrete evidence whether they’re the same as GD dimensionally, will find out soon.
#558 ·
From what I read, GR coilovers are direct bolt on for VA, people had success using GR knuckles and said Subaru front suspension geometry remain largely unchanged. Got a good deal for the VA knuckles so we’ll see.
The rear is more straightforward, I’ll just be getting new 5x114 hubs to press into existing rear knuckles.
#559 ·
My mistake, I was thinking about the rear hubs as far as geometry. It would likely work, go ahead and post up your results!
As far as the rear, if you're running R160 rear knuckles, the 5x114 hubs won't simply press in. The entire knuckle is different.
