Soo...
My 1999 JDM Subaru WRX was broken into and the thief tried to steal the car and failed. They broke the ignition switch pretty bad (also popped out) and cause my steering to lock. I cannot stick a key or flat head screw driver to unlock the steering column.
My question now is what to do? Also, If I were to get my hands on a 1999 Subaru USDM 2.5rs steering column, would it be a exact swap without any issues?
I posted this on ''Interior & AV'' also but idk if it belongs there.
Thanks for the help in advanced.
Screenshot by Lightshot
Here are some pictures I took today. Would changing the ignition cylinder work? USDM to JDM
Update:
Soo i finally got time to take apart some more things on the car.
I took the starter switch out of the ignition lock to try to start up the car, but it did not work. There is electricity in the car, but the dash does not light up. But there is a constant beeping noise like when you have you key in the ignition with the doors open. Seems like the turbo timer has been cut and stolen, soo I attached the two blue wires underneath the car and tried to start the car once again, but nothing happened.
some pictures
503 Service Temporarily Unavailable
http://prnt.sc/eekt91
http://prntscr.com/eekvkq
http://prntscr.com/eekw82
http://prntscr.com/eekwft
could it be a starter relay? Do i have to get a ignition lock in order for me to start up my car?
And thank you for all the comments you guys.
Update:
some pictures
