headlight problems......
903 views 4 replies 4 participants last post by  guesswho
#1 ·
I've got a 95L all stock and the passengers side headlight will go on but is alot dimmer then the drivers side headlight. I've changed bulbs a few times in it and even replaced the whole headlight and still the same thing happens. When the highbeams are turned on the passengers side gets even dimmer but the drivers side functions fine. Was thinking maybe the stalk or a relay? Any thoughts?
#4 ·
I would check the grounding where it connects to the body. Ensure that it's clean. You could try connecting a wire with some crocadile clips on both ends from the globe (earth side wire) to the earth terminal on the battery. this would indercate if it's an earthing problem. Good Luck
