DIY VA Complete Front subframe Swap
2.5K views 29 replies 6 participants last post by  seraphinwolf187
#1 ·
No pictures yet cause its raining and I was hoping to get it all ironed out before starting this post but its been a bit since i told some people i would let the cat out of the bag so here it is ill update (with parts links) as I finish off the little things BUT the major hurdles are done
I wanted a faster steering rack for rally cross and read this DIY and figured if they got it to fit a GD then it should fit a GC - VA steering rack in 08 STI
Drank a beer and found a complete 2019 STI subframe locally for 350 so i had to pull the trigger on seeing if I can get the full subframe in
Goals
  • Cheap 13.5 Quick steering rack out of the 2015-2020 STI
  • Bolt in
  • Hopefully no custom parts
Problems and solution
- VA subframe is thicker (due to double layer) so you need longer bolts, Some people say you need to widen the holes (GD) i just used a half size down standard grade 8 and fits fine (ill measure the bolts)
- Control arms - they are different so I used GD alum control arms so i would assume GC would fit
- Control arm front bushing - So GC -55 MM bushing - GD 61 MM bushing - VA - 57MM Bushing i bought some white line VA bushings and had to remove a metal shim out of them and they fit perfect in the GD alum control arm - Rear mount is standard GC
- Tie rods - inner tie rod to rack is 20X1.5 GC is 14x1.5 and they are longer - Two options here Thread Adaptors and GC inner and outers. I didn't like this idea to much and tried the GL outer tie rods on VA inners like the original DIY said fit. But for the life of me I can't find a passenger outer tie rod that fits the knuckle i have tried 4 different ones the driver sides fit fine but every passenger side is to small. So i going to trim down the inner and a GC outer tie rod
- Steering link - Currently the biggest issue - Tried GD steering column with GD link and its too long. Tried GC column and measured and the GC - GD steering adaptor might work going to test fit it from a buddy later this weekend I hope. if not ill just shorten the VA link
- Power steering - I need to test fit the GC lines to check threads but I'm running legacy High PSI and WRX return line to a separate reservoir like the WRX (I suspect the WRX high PSI would fit but I had the Legacy line already) Might have to make a PS line I'm not sure for NA GC
- Exhaust - I have a H6 in the car so I can't answer any fitment questions as far as GC NA or Turbo headers. but the VA still had a turbo up pipe so I would think it would clear
- Sway bar - clearance will be dependent on what exhaust you using - I have a H6 so can't help to much here
Not the hardest thing i have done but i wouldn't venture down this road with a car you need to drive the next day
I know I suck for making a DIY with out pictures but ill get some soon (Feel free to shame me)
#3 ·
Whoa. Lots of interesting things to unpack here. Above all it's cool to confirm that the VA subframe does bolt up (so long as you get longer bolts to account for the thickness). Along with running the faster steering rack, I wouldn't mind if I had an overall thicker subframe to prevent flex. If anyone is swapping motors and therefore swapping from an NA to turbo subframe, this could be a really good option. I have some misc questions so I'm gonna just list em out
The tie rod troubles you ran into are confusing to me. You said the GL outers on VA inners worked for the driver's side but not the passengers? Are they asymetric or something? I've only ever seen symetric tie rods on subaru's but I don't have any real GL experience so I might just be out of the loop.
Any pics or further details about the shim you had to remove fromthe whiteline control arm bushings?
Curious to hear what you eventually come up with for the steering link. Shortening the VA link sounds like a solid plan if it can just be trimmed on either end.
Any idea what the weight difference is between the GC and VA subframes?
I remember an old nasioc thread detailing putting a 2015 STi rack into a GD. Don't remember the specifics but I think the threads at the rack were different because that person chose to just make their own PS lines from scratch.
Finally, I'm curious if you considered putting a quick steer column in instead of doing all this subframe work, especially since you ended up swapping out columns anyway to figure out the steering link thing. Don't get me wrong this is all great info and I'm glad you're doing it, but if the goal is just to get faster steering wouldn't a simple column swap make more sense?
#4 ·
I don't have any GL experience either ill get a picture up of them once it stops raining but they have a bend to them i assume to clear the wheel. i don't know why i can't find a passanger side that has the larger tappered bolt for the hub but im tired of buying random ones hoping to find a match to the driver side. (ill get a picture to explain later)
Yes ill get a picture up with the other pictures. its a metal thrust washer on the bushing since there rear control arm bushing on 08 and ups are designed to flex (dumb as shit it my mind) and not pivot on a bolt like the pre 07 i think its to add stiffness.
Heavier due to more metal lol ....... Honestly no idea its not WILDLY heavy or anything its got some placed that its double reenforced but i could still pick up the whole thing and move it around
Unsure on that. my 02 Legacy lines threaded right on to the lines coming off the rack at the steering connection. So im going to see if the VA lines attach to my GC rack now that its out and that will confirm threads matching
Valid question a few things drove this plan
-Faster column cost more (im in this about 500 bucks and have all new tie rods)
-The car is a rally cross car with maybe hopes of some stage rally in the next couple years so durability is a key factor and i don't know how the gear reduction columns would do with the dust and constant vibration
-Currently nothing is really custom so its all parts i could get a dealer or junk yard (minus steering link which i thought i was going to get away with a GD column since the few GD swaps i have seen don't seem to mention a need for a steering link)
-also why not lol
#7 ·
Any updates? I’m in the midst of considering this or a GR subframe and yanking my GDB subframe out from the main project and “handing down” that to my other wagon.
So one of the first things that caught my attention regarding the VA subframe, it candles the engine like 10mm lower. There’s a few other considerations but the gears in my head are spiraling and blasting is so many directions trying to sort out geometry and other specs.
One issue that’s got me caught up on being flip flopping on VA vs GR subframe is the LCA mounting location. The VA mounting points are wider apart, which is appealing to be because of widening my track, BUT it changes the geometry of the LCA and the caster. I have adjustable LCA’s, but not able to adjust from the caster if you know what I mean.
As for other documentation on subframe differences there has been a thread on NASIOC I’ve been going through but not yet sat and tried to block out noise and distractions(AKA hard ignore the wife and kids) enough to map it all out.
#11 ·
Added a few crappy pictures I have to pull the steering link out before the next race and I’ll take a better picture but basically I couldn’t find an OEM joint that was correct gd was too short VA was long so I just cut the VA shorter and works great
Tie rods (I havnt officially aligned the car outside of drinking beer with a tap measure). But the only real DIY was on a GD and they said the outers were too long.
So I’m running VA inners and GC outers and it works alllllmost fully bottomed out but there are a few threads left and if I had to I could cut an inch off the outer tie rod and have plenty.
(I’m on GD sedan control arms so alittle wider)
Raced last month and the VA rack was great
#14 ·
I’d be interested to see how the specs would look on an alignment machine. Because it definitely has got to shift how the arm pivots with that new angle. I’ve got adjustable arms but I’m pretty sure they only adjust straight out.
Either way I think I’m gonna move forward with planning to do this and accept that I may want/need a different arm.
#20 ·
the rear control arm mounting point is the frame of the body so that never moved. and since the front mounting lines up then the control arm never moved. not sure what new angle your referring to. if your talking about the GD control arms. GD control arms have been used on GC turbo swaps for 15-20 years just fine some just prefer the wagon so they don't have to roll fenders (depending on the wheel)
#24 ·
where is this 10 MM drop coming from i have never heard of this?
^ this is the first I'd heard of it
