21 - 25 of 25 Posts
Discussion starter · #22 ·
Discussion starter · #23 · (Edited)
Old Post update
Hi,
Not wanting to hurt anyone's feelings, but there is some mis-info in here about the 2.2/EJ22e (most of this info is on Wikipedia).
For US models:
'90-98 EJ22 were all considered Phase 1.
'90-'95 were all dual-port exhaust and had hydraulic lash adjusters (HLAs)- no adjustment needed
'95 was the 1st year of the OBD2 and EGR valve on the Automatics only.
'96-'98 had single-port exhaust
'97-'98 changed to solid valve adjusters (adjust @ 100K miles) and had higher compression pistons - but still Phase 1.
'99-'01 EJ22 was the Phase 2. For swap reference you can't (easily) swap Phase 1 and Phase 2 long blocks (intake/heads/block). But the short block of almost all '90-2003+ Phase 1 or Phase 2 can be intermixed....just swap the heads and intake to match the car year. Usually, use the head gasket that matches the block...but that is up for negotiation.
TD
1996 GC - GF Impreza Cruise Control install
FHow do I add cruise control? I tried looking for another thread but I can't find one.
I found a thread. http://www.rs25.com/forums/f105/t113764-diy-cruise-control-install-98-rs.html
I just did this on my '96 Impreza LX w/an AT trans.
Get the following parts:
1. Cruise control module - must match your trans -AT or MT (they are labeled on the module) - the PLUG/connector IS ALREADY THERE and is taped up under the dash just above your left foot. I mounted it to a spot under the dash w/zip ties.
2. Dash CRUISE switch - the PLUG/connector IS ALREADY THERE - just remove the 4 screws on the console piece around the gauges, pop-off the 'blank', plug in the wiring connector and insert the new switch.
3. Brake switch - the cruise brake switch is PLUG/connector IS ALREADY THERE taped just above the brake pedal- just swap switches - Note the threads/adjustment of the existing switch to match the new one...or your brake lights may not work or cruise may not easily disengage.
4. Actuator/Vacuum hose/T-connector/Brackets - under hood connects to throttle cable. PLUG/connector IS ALREADY THERE taped to the harness near the passenger side strut tower. It mounts in the stock location- the Forester brackets worked on my Impreza, too. Use the T-connector to splice into your vac lines on the intake manifold.
5. Steering wheel switch/lever (there is no need to remove the steering wheel!) - 2 star screws to remove to get the airbag off (read up on here about what to do to not set it off - I just removed the Neg battery cable, pumped the brakes a few times), remove the right side of the spring loaded horn actuator, pop-out the blank for the switch to pass thru on the steering wheel, swap the wiring for the switch - uses the same connectors - no splicing necessary, put it back together....
I got all my parts from a '98 Forester and they worked EXCEPT for 2 issues:
1. The cable from the actuator was too short, but it'll still work.
2. The steering wheel switch doesn't work for the Resume or Cancel features, but everything else works. I may try swapping in an 'age-appropriate' Impreza module to see if that fixes it.
Parts pic (the module in the upper right is for keyless entry I hope to install):
Actuator install:
Throttle cable install - note where the end of the cable 'hooks' - the one on the left in the pic is the cruise:
21 - 25 of 25 Posts
