Tools Required:
- Sockets; 8,10,12,14,17mm both deep and shallow well
- Box wrenches in the same sizes as above
- Various extensions
- Breaker Bar
- Phillips and Flat screwdrivers
- Pliers
- Black Marker, White out
- Rags
- Engine Hoist w/ chain and/or stabilizer bar
- Floor Jack, Scissor jacks, Jack Stands x2
- Pry bar
- Metal putty knife
- Hammer
- PB Blaster
- Service Manual
Optional:
- Never seize
- Plastic sandwich bags
- Various lamps
- Various plastic containers
- Plastic ties and straps
- Protective eyewear
- Engine Stand
- Air tools
- A Friend
Fist things first pull the car into where ever you are undertaking this, make sure you have enough room to move the hoist around. Also make sure you have enough room above so that the motor and hoist will clear everything above the car. Next take a bunch of pictures from different angles of your engine bay and/or have another RS there to compare when putting everything back together. Another thing (which as you can see I didn’t do) is to wash the engine bay.
Note:
After removing any nuts, washers, and bolts if at all possible put them back in their original location. You will end up with quite a pile of parts after this and the last thing you want is extras! Another option is to label plastic bags and put the parts in there, or you can place parts in piles together. Just try and keep the parts organized.
All work was done on a 2001 2.2L Impreza L, I noted where I remembered the differences were with the RS
This writeup is for a Manual Transmission, there are differences for a Automatic Transmission please check with the service manual
