Transcribed from WAC's Site
This installation will upgrade the rear drum brakes on an AWD Impreza or Legacy to rear disc brakes. I performed this modification using research information obtained from the North American Subaru Impreza Owners Club (i-club) and Rallispec. The only 1993-2001 Impreza's with rear disc brakes are all 2.5RS models and certain 2.2L models in 1995 and 1996, including the 1996 Impreza Outback Sport. This documentation is based on the install on my 1997 Subaru Impreza Outback Sport, which has ABS. Your installation may differ slightly if you do not have ABS.
Note: these instructions are intended for someone with reasonable automotive repair experience and knowledge. Many details have been omitted, as they can be found in other literature such as Haynes' excellent Subaru Legacy Automotive Repair Manual (1990 through 1998). Missing details include: suspension assembly/disassembly, brake assembly/disassembly, parking brake adjustment, and brake bleeding. However, I have included pictures wherever possible to aid presentation and to provide helpful hints.
Materials Required:
Tools Required:
Materials Required:
- 1 set complete and functional rear knuckle assemblies from any 1993-2001 Impreza or Legacy with rear disc brakes, consisting of:
- AWD knuckles, with hub and bearings
- Backing plates
- 10.1" solid disc rotors
- ABS sensors and cables (if applicable, and optional)
- 1-pot brake calipers
- Brake pads (new or used)
- Disc brake seal kit (optional, Subaru part number 26297AA040)
- Rear disc brake hoses, Subaru part numbers 26531AA041 (RH) and 26531AA070 (LH), or aftermarket equivalents.
- Parking brake cables (from Impreza RS or Legacy, but Impreza RS will be of proper length), Subaru Impreza RS part numbers 26051FA140 (RH) and 26051FA150 (LH)
- Brake fluid, DOT 4
- Shop rags
Tools Required:
- 10mm, 12mm, 14mm, 17mm, 21mm socket (ratchet) wrenches
- 32mm hub socket wrench
- 14mm deep socket wrench
- 12" or longer breaker bar
- 4" and 6" socket wrench extensions (optional)
- 10mm, 12mm, 14mm, 17mm open-ended wrenches
- 8mm, 10mm flare nut wrenches (for brake bleeding, hoses)
- 2-ton floor jack(s) or equivalent
- 2-ton jackstand(s) or equivalent
- Oil/fluid catch pan or suitable container
- Speed bleeders (optional)
- Pliers (optional)
- Small flat-blade screwdriver (optional)
