41 - 54 of 54 Posts
2000 GF8 SportWagon 257 6MT
Discussion Starter · #41 ·
Pretty Big Update on page 1 Heres the old build for comparison
Current mods are:
Exterior:JDM STi Clear corner lights
JDM Sti Sport Bumper/Wr Bumper (Oem Option)
JDM Smooth Rear Bumper
JDM Front and Rear Lightweight Bumper Supports
JDM Plate Bracket
JDM Sti Mid Wing
JDM Sti Top Wing
JDM RA Roof Vent
JDM Side Skirts (OBS did not include skirts)
93-01 Impreza Ganador Aero Mirrors
Bakemono Sport Bumper Lip
Bakemono 22b Vents
Awaiting Paint Job
Interior:
98-01 Dash, Door Cards and all Black Trim Plastics
JDM Version 6 V Limited DCCD Cluster
Version 6 Sti Seats
Version 2 Sti Nardi Wheel + OEM Hub
06 WRX Black Carpet
05 STi Pedal Box
ARC Titanium Shift knob (Machined for 6MT)
Cobb AP + Window mount
Engine:
USDM STi EJ257 AVCS
VF-39 Turbo
05 USDM STi UEL Headers
Grimspeed Uppipe
iWire Harness Merge #1130
Aisin Timing Belt Kit.
Koyorad 04-07 STI Aluminum Radiator
Iwire Gc to Gd Radiator Shroud
Spal Slim Fans
Weapn-R Coolant Overflow + Wiper Fluid Res
05 STi Fuel Tank
K&N Typhoon Short Ram Intake *
Invidia Catless downpipe Pipe *
Custom Garbage Catless Midpipe *
HKS Carbon Ti Muffler (*Not Yet Installed, For B.A.R. testing)
Crawford AOS (Not Yet Installed)
Suspension:
05 Sti Rear Subframe
05 STi Front Subframe
05 STi Steering Rack
Kartboy Rear Subframe Lock Bolts
05 STi Aluminum Lateral Links
05 STi Aluminum Front Control Arms
05-07 Sti TEIN Street Flex Z Adjustable Coilovers
05-07 Sti Eibach 25mm Swaybars
05-07 Sti Kart Boy Solid End Links
Alignment Specs:
None
soon
Wheels & Tires:
Advan RG-2 18x8.5 +50
245/45/18
Gorilla Open Ended Lugnuts
Brakes
05 STi 1 1/16th inch Master Cylinder
05 STi booster
05 STI Brembo Front and Rear
Dbw Drilled and slotted 1pc Front Rotors
Hawk Pads
Stoptech Stainless Steel Brake Lines
Drive Train:
USDM 05 STi DCCD 6MT
Zf Designs Full Face, Carbon Kevlar
05 Sti R-180 Rear Diff with R160 flange for auto driveshaft.
Auto impreza Driveshaft
05 STi 5x114.3 hubs
05 STi Axles
DCCDPro Deluxe DCCD Controller(manual/Auto mode with STi switches and STi Cluster interface)
Kartboy Rear Shifter Bushing
Discussion Starter · #42 ·
Here are some shots from my Trip to SF and San Jose for the Gc Society Meet/Cruise
Perfect trip for the break in miles that i needed on the new shortblock
i had an awesome time hanging out with friends i met here and on facebook!
Land vehicle Vehicle Car Sedan Subaru
Land vehicle Vehicle Car Motor vehicle Steering wheel
Road Windshield Road trip Mode of transport Lane
Vehicle Car Mode of transport City car Road
Motor vehicle Mode of transport Bridge Vehicle Car
Discussion Starter · #43 ·
Build Update on page 1, quoted below is the last phase of the build.
since then i have spun another bearing, ripped it all apart and started over..
IAG Trojan Short block
IAG Oil pan kit (race)
ARP 1/2 inch head studs
Je Proseal Head Gaskets
Heads Rebuilt by Outfront
Turbo Rebuilt by Ruben @ Socalporting
Radium AOS
1320 equal length headers (perrin replica)
CX racing FMIC kit
Shaved 2.5i NA Long runner intake manifold
Aluminati 19mm Phenolic spacers
Aluminati Coolant reservoir mount for 2.5i manifold
Company23 Anti Surge Boost controller
Turbo Smart Murray Clamps for the fmic couplers
Iwire speed density kit
Koyorad sti Radiator
Replaced Every single part that had oil travel through it..
Current Build List:
JDM Plate Bracket
JDM Sti Mid Wing
JDM Sti Top Wing
Bakemono 22b Vents
Awaiting Paint Job
Interior:
98-01 Dash
LHD Upper Dash Cubby/Airbag Delete
Oem Compass pack surround
Brett Woods CNC Gauge pod
VDO 50mm Oil Pressure
VDO 50mm Oil Temp
VDO 50mm Coolant Temp
Custom white faces for the VDO gauges from Illumisthetic compliments of Daniel Lora aka @Dl3r on instagram
JDM Impreza Stainless Door sills
JDM Version 6 Door Cards
JDM Version 6 V Limited Blue DCCD Cluster
Version 6 Sti Front Seats
Version 6 Sti Wagon Rear Seats
HKB Boss Hub, Nardi x Vertex 340mm Wheel
01 Rs Dark Gray Carpet
05 STi Pedal Box
ARC 6spd Shift plate
Engine:
EJ257
Sti Nitrated Crank
Pauter X beam Rods
JE Forged Pistons 99.5mm
King Race bearings (Xtra Clearance mains)
ARP 2000 Head studs
Zinc plated hardware
Heads: Rebuilt 05 Sti AVCS
Fuel: Outfront Top Feed Fuel rails
-6AN Braided pressure fitting fuel lines
Aeromotive FPR
Cobb Fuel pressure sensor
Rocksteady Tuning Flexfuel kit with -6AN Fittings
DW:: inline Fuel Filter
Turbo: Blouch Dominator 3.0XTR bb
Exhaust: DC UEL Headers Ceramic coated
Grimspeed Uppipe with 44mm Ewg bung
Tial 44mm EWG
HKS Carbon Ti Catback
Intake: Agency Power Solid turbo inlet
14 STi TMIC
Cooling: Koyorad 04-07 STI Aluminum Radiator
Spal Slim Fans
Wiring: iWire Harness Merge #1130
Misc: Aisin Timing Belt Kit.
iWire Gc to Gd Radiator Shroud
Chase Bays Power steering kit (Awesome purchase)
05 STi Fuel Tank
Suspension:
Whiteline Balljoints/TieRods
Alignment Specs:
None :( soon
Wheels & Tires:
Rays Volk TE37 OG Mercury Silver
17x7.5 +45
Brakes
05 STi booster
Hawk Pads
Drive Train:
USDM 17 STi DCCD 6MT
3.54 STI R180 Rear Diff
05 STI Driveshaft
05 STi 5x114.3 hubs
05 STi Axles
VSS Pro Speed sensor iWire PNP Kit
Tuned At Church Automotive making 393Whp/430Wtq (e85) on the dynojet dynomometer
Discussion Starter · #47 ·
Love everything about this vehicle...except the spun bearing - that sucks. Is the pretty piece behind your battery the washer reservoir? Where'd you get that?
that was a part from WeapnR on ebay i think, take note that the coolant overflow is ineffective because it enters the top of the reservoir... i got rid of it a while ago and am now using a JDM in fender tank.
Discussion Starter · #48 ·
What oil you like?
right now i am running 5w40 Break in oil from Motul as per IAG break in procedure.
after that because i am running e85 70% of the time i will use 10w40 Motul 300v or 6100 synergie
Discussion Starter · #49 ·
Wagon is way cool.
How's the 1320 header? Look to be decent from pics online. Price seem more than fair if they don't crack right away.
honestly the header is super nice, the welds seem really nice. will report back with any issues in the future if there are any.
Discussion Starter · #50 ·
Excuse the Blue front bumper, working on something with Bakemono.
86785
Heres the latest interior shot in 2021 New Bride Vios 3 Reims and the guages are now wired. they still dont work that well, but they light up...
86786
Here is the engine bay right now, i'm not completely happy with it, but it will do for now..
Vehicle Car Hood Automotive lighting Motor vehicle
The booty. i removed all the stickers and added this cool Oem 22b Quick steering decal.
Eventually when the car is painted i have a brand new oem Trunk Decal i will be using and that'll be it for a while.
86788
86789
Discussion Starter · #52 ·
So much win.
We're you able to just bolt up your dbw to the na intake? Or was there some fab involved.
Keep up the good work.
It didn't bolt up easily, no.. well not in the orientation needed to clear Stock location turbos.
if you're rotated i believe it would fit in the normal rotation, i had to however rotate the throttle body 90 degrees and shave some off of the coolant passages and off of the top of the manifold for clearance..
it came to my knowledge AFTER i did all of this that you can use a throttle body spacer and solve all of the issues i ran into... derp.
41 - 54 of 54 Posts
