1998 Subaru Forester 5 Speed with EJ22
Located in Fairmont WV or shipping isn't a problem just message me for a quote. If you want pictures of a certain part or interested in something not listed just ask.
Engine, Drivetrain, Suspension & Brakes
EJ22 Phase I Long Block Fully Assembled $350
EJ22 Phase I Short Block Fully Assembled $250
EJ22 Phase I Heads Complete $200
Intake Manifold $80
Throttle Body $40
Engine Harness $50
5 Speed Transmission(No Center Diff or Rear Transfer Gears) $200
Straight Pipe Cat Back Exhaust w/Resonator $125
Rear Differential Carrier 'T' Subframe $50
Engine Crossmember $50
Rear Crossmember $50
Transmission Mount $20
Axles $50
Control Arms $25
Sway Bars $20
Lateral Links $10
End Links $20 set
Front ABS Sensors $15
Front Brake Calipers $25
Intake Scoop $10
Intake Resonator Inner Fender #A32AC08 $10
Clutch Slave Cylinder $20
Crankshaft Pulley $30
Plug Wires $30
Ignition Coil $30
Air Assist Injector $35
Fuse Box $25
Timing Covers $10
Power Steering Pump with Reservoir $75
Power Steering Pump Bracket $10
Radiator $50
AC Compressor Bracket $10
AC Lines $30
Alternator $65
Wiper Motor $30
Fuel Pump $20
Washer Fluid Tank $15
Pitch Stop Mount $10
Gas Cap $10
Oil Dipstick & Tube $10
Oil Cap $5
Oil Fill Neck $5
Radiator Mounts $5
OEM Headlights (work but small BB size hole in glass) $40
Fog Lights $20
Headlight Trim $15
Doors $50
Door Handles $15
Hood $50
Driver Fender $50
Front Bumper $50
Front Bumper Beam $50
Grille $40
Side Skirts $50
Driver Mirror $15 (busted glass)
Wiper Arms $30
Rear Wiper Arm $15
Trim & Weather Stripping $10+
Left Front Engine Bay Harness $50
Instrument Panel Harness $20
2002 Rear Seats $40
2002 Center Console $40
2002 Rear Door Cards $25
2002 Carpet $50
Seatbelts $40
Dash $50
Glove Box $30
Passenger Airbag $40
Driver Airbag $40
Steering Wheel $20
Steering Column $50
Key Set: Ignition, Locks and Key $50
Door Handles $10
Window Motors $25
Rear View Mirror $20
Dome Light $10
Map Light Assembly $35
Headlight Switch $25
Wiper Switch $25
Master Switch $25
Window Switch $10
Door Lock Switch $10
Mirror Switch $10
Cruise Switch $10
Rear Wiper Switch $10
Rear Wiper Motor $25
Interior Plastic Pieces $10+
Speaker Brackets $10 set
LEDs for map, dome and rear interior lights $5
Intake Manifold $80
Throttle Body $40
Engine Harness $50
Axles $50
Control Arms $25
Sway Bars $20
Lateral Links $10
End Links $20 set
Intake Scoop $10
Plug Wires $30
Ignition Coil $30
Fuse Box $25
Timing Covers $10
Radiator $50
AC Lines $30
Alternator $65
Wiper Motor $30
Fuel Pump $20
Gas Cap $10
Oil Cap $5
Oil Fill Neck $5
Radiator Mounts $5
Fog Lights $20
Headlight Trim $15
Doors $50
Door Handles $15
Hood $50
Driver Fender $50
Front Bumper $50
Grille $40
Side Skirts $50
Wiper Arms $30
Rear Wiper Arm $15
2002 Rear Seats $40
2002 Carpet $50
Seatbelts $40
Dash $50
Glove Box $30
Driver Airbag $40
Steering Wheel $20
Steering Column $50
Door Handles $10
Window Motors $25
Dome Light $10
Wiper Switch $25
Master Switch $25
Window Switch $10
Mirror Switch $10
Cruise Switch $10
