1 - 3 of 3 Posts
96 Impreza GM4.5
ok I got a quick question.
I have a 96 impreza lx and I wanted to upgrade the front brakes to 03 wrx... can I still use the same struts or do I have to use the wrx front struts? im kind of lost here can anyone help my on this thanks.
2016 Golf R
All you need is the rotors and the brakes+brackets. The brakes are pretty much identical to RS, with the exception of larger rotors. A bigger improvement would be going to LGT brakes.
Edit: Your existing struts are fine.
overdeveloped beater
Do something with the dustshields too....either bend it out of the way or remove it. The Rotors are going to be much bigger than the diameter of the dustshield and will squeal unless you take care of it.
1 - 3 of 3 Posts
