1 - 10 of 10 Posts
2000 Impreza RS
If I swapped a WRX engine onto my 00RS transmission, what other parts will I need to make it work with the OEM RS tranny?
2000 Impreza RS
Discussion Starter · #4 ·
I don't use the WRX clutch master cylinder? What about an RS stage 1 or 2 clutch?? what brand should I go for and should I do a lightened flywheel at the same time?
98 Red L 2.2L 5spd
no not really. clutch and flywheel is up to you. just remember that when driving just treat it with respect. dont go 5k launches and you'll be fine. the rs transmission will hold power fine.
wood grain grippin'
v2 STi wagon
If it were my car, I think I'd just get the ACT kit with the street disc and heavy duty plate. and Sportlite flywheel
RSTI
I ran around on a WRX swap with a RS tranny and ACT sport clutch. It was great. I then swapped in a RA tranny. Then put the RS tranny into my wagon with an STI version 3 engine. The engine lasted about 300 miles but seemed to hold the power fine.
cheers
poorman
1 - 10 of 10 Posts
