1 - 3 of 3 Posts
I just did belts and idler tensioner after rebuilding a power steering pump and doing inners and outer tie rods.
Using a recommended 5th gear and breaks to torque down the harmonic to 130ft/lb now the car turns over and idles great, just cannot go into gear unless the car is off.
What did I break
pictures of clutch fork attached, I believe there should be a spring in the fork? Looking at another 5speed in my shop.
83784
83785
Super Moderator
2000 RSTi
Tighten the clutch cable a little bit, they stretch out over time.
1995 EZ30 Coupe
Did it work?
That fork doesn't look like it's sitting at the correct angle to me, anyone concur? I've heard of them bending/breaking where they pivot, but you probably would have noticed that.
1 - 3 of 3 Posts
