1 - 8 of 8 Posts
'04 PSM WRX Premium
Yes, that H1 kit that you posted will fit. Headlight-wise the RS and WRX are the same (STI is different).
However, you shouldn't put HIDs in reflector housings. Scatters light too much. Google and look into that.
I'd suggest a good bulb. Osram Nightbreakers, Philips, etc.. Try PowerBulbs.com
I've used stock and blue coated bulbs, HIDs, and the above bulbs in stock housings and the best light output and seeing was from the Nightbreakers.
Discussion Starter #4
Thanks for that, will definitely look into brands/housings. :)
Discussion Starter #6
You were saying RS and WRX are the same for head light? What about body shape?
I suggest projector with hid. Look into morimoto.
Thanks for the recommendation ill look into that :)
2004 WRB WRX Wagon
If you are dead set on gettings HIDs. Buy STi housings. They bolt right in and are HID stock.
1 - 8 of 8 Posts
