1 - 1 of 1 Posts
We are proud to announce we have offered our support to the Wicked Nasty Rally team by helping to get their GC Subaru Impreza rally ready with our highly successful R1 Rally Suspension.
R1 Rally Suspension:
R1 1-Way Stage Rally Suspension : Flatout Suspension
About the R1 Rally Suspension:
The R1 coilovers include all of the features from the 5700 model, and then turns the dial up a notch. By using an extended inverted shock cartridge, the Impreza is able to go 1-2" higher than OEM ride height. The damper fluid is moved away from heat areas such as the braking system or in some cases, exhaust systems to avoid overheating the fluid and causing damper fatigue under extended use. We have done a lot of testing; both high and low speed to measure fatigue and internal heat with great results. The inverted setup handles side loads better and is more durable under extended use, such as in rally applications. Another advantage is the reduction of unsprung weight by moving the heaviest portion away from the hub area. This coilover is best suited for rally, but is compliant enough for street use.
This is the perfect coilover system for the person who wants a solid, dependable rally suspension but on a budget.
Features
Single adjustable
15 step rebound
Steel monotube construction
57mm Shock cartridge
Inverted piston
50mm longer shock cartridge than std.
Adjustable height spring perches
Adjustable height lower mounts
Reinforced steel lower mounts (8mm mount tabs)
High Pressure nitrogen charged
10mm thick fixed pillowball steel upper mounts
280/225 standard rates
12" front spring
12" rear spring
Customizable spring rates
Damping sweep for front 600~225 springs, rear 500~170
1 - 1 of 1 Posts
