guys, the tranny has seen way higher temps than this and has NEVER had a problem. and i have NEVER heard of ANYONE having problems at only 5psi of boost. the 4eat can take a shit load of power. i do not abuse it. i dont do N drops, and i dont sit with my foot on the gas and brake pedal all day. this happens ONLY under WOT and it comes on right away before the tranny has alot of time to heat up a great deal.
but i have been planning on changing the fluid to some redline auto tranny fluid. there is a "trick" that can be performed and the tranny will tell you what the problem is. the at oil temp light doesnt always mean that its the oil. it could just be a bad ground (could have came loose when i was installing the SS Map).
oh yeah and lets add this little tidbit....depending on the fuel map i use, it goes off. with this map that 8c has given me for off boost, it comes on. before that, i had it so it would never come on. and before that between my "tuning" it would go on and off depending on the A/F (at least thats what it seemed). i have no idea why my fuel map would have effect on it. ive driven the car HARD with other fuel maps taking it past 100mph in WOT and along some tough roads and it never went off. but then just getting to 40mph in WOT it likes to go off.
