1 - 20 of 696 Posts
01 white GF
This is my second gf and soon to be first gf8! currently swapping in a v6 sti motor and transmission and repainting the whole car. all work being done by me except my wiring harness which i have sent to iwire. hopefully the white mystery machine will be road worthy soon.
Current picture
Suspension
[x] Flatout coilovers
[x] Cobb 25mm adjustable rear sway bar w/ stiff body mounts
[x] Kartboy front and rear end Links
[x] Kartboy rear subframe bolts
[x] Diy Rear strut bar
[x] Diy fender braces
[x] Diy rear power brace
[x] Diy rear diff brace
[x] Group n sti pitch stop
[ ] Cusco rear subframe brace/diffuser kit
[ ] Whiteline lateral links
[ ] Whiteline front roll center kit
[ ] Aluminum control arms w/ upgrade bushings - have alu arms, need bushings
[x] Volk Racing Ce28 17x7.5 et48 with 225/45/17 tires
[x] Work Emotion CR 17x7 et32, going to throw winter tires on them
Brakes
[x] Rear Disc swap
[x] Stoptech Stainless steel brake lines
[x] GrimmSpeed master cylinder brace
[x] 2004 Sti brake booster and master cylinder
[x] 4/2 pot brake upgrade.
Motor and Exhaust
[x] v6 ej207
[x] hks grounding kit
[x] Grimmspeed Uppipe
[x] turbosmart 44mm external wastegate
[x] Invidia downpipe
[x] Perrin catback
[x] GM 3port ebcs
[x] 565cc sti sidefeed injectors.
[x] Project lambda tune 262whp 247 trq
Drivetrain/steering
[x] Kartboy front/rear shifter bushings
[x] Short shifter w/ extension and Rally Tech weighted knob
[x] 2005 sti steering rack, 2.6 turns lock to lock
[x] ChaseBay stainless steel clutch line
[x] Kartboy transmission point bushings
[ ] Whiteline steering rack bushings
[x] Excedy hd stage 1 rated to 319 trq
[x] Competition weight flywheel 13.5 lbs
[ ] Carbon fiber drive shaft
[x] Moonroof
[x] JDM tail lights
[x] JDM Clear corners/fender blinkers
[x] JDM V6 Sti grill w/ pink i badge
[x] JDM roof rails
[x] JDM smooth rear bumper
[x] Liberal Sports rear lip
[x] Side skirts
[x] Flat metal fuel door
[x] V6 front bumper w/ p1 lip and fog covers
[x] Pearl white paint job
[ ] Roof antenna
[x] 2011 Sti seats
[x] v7 sti momo steering wheel
[x] JDM red hazard button
[x] AEM wideband air/fuel gauge
[x] Defi boost gauge
[ ] black rs interior
[ ] black carpet
Short term goals
Sti tmic
Powder coat intake mani wrinkle black
Turbo inlet pipe
Convert to topfeed fuel rails and larger injectors
Air Ride
Get some work vsxx :drool:
Long term goals
Shave engine bay
Bigger turbo
Rotate intake manifold for a fmic
Put a ej257 in between the 207 heads and blow some **** up
Parts numbers I've used with price from local dealers. Will update whenever I use a new one
99 Impreza RS Maf sensor
22794AA000 - 69.71
Maf sensor screws
043504100 - .30
Downpipe exhaust bolts
44059AA030 - 9.25
Impreza RS hydraulic clutch hose
37251AC001 - 26.00
Clutch/Brake line gaskets
114130151 - .98
Cross spring for 4 piston wrx brakes
26232fa020 x 2- 18.83
Pins that holds cross spring in
26228FA000 x 4 - 7.89
RS Front Bumper Skin (99-01)
57720FA280 - 249.95
Bumper clips
57728AC090 - 2.50
01 white GF
rear disc swap got here today
going to buy stainless steel lines and better pads
anyone know difference between impreza obs front brakes and impreza rs?
wondering if the calipers and rotors from an rs would be an upgrade for my obs.
01 white GF
Discussion Starter #4
oh and thanks teecers, i like wagons more than coupe/sedans personally :)
and i cant take credit for that picture it was all iphones doing i just picked a spot on way home from work
i like that spot cus a little farther right and you can see mt rainer, little to the left mt baker, for people who know about WA or rainer beer, which is now made in California :crazy:
I opened this thread and thought, "Oh, GF as in the model, not GirlFriend." :lol:
Clean man. Sad to see the first one go though.
01 white GF
Discussion Starter #7
i am too but back bumper is ziptied on cus mounts all rusted off
rocker panel is rusted, by antenae is rusted
and i dont have a welder otherwise id try fixing it
but thanks for the compliments
01 white GF
Discussion Starter #8
bought a moonroof yesterday and after reading nothing but people saying its stupid to put them in a car that didnt come stock with one cus itll rust and youll die i still dont care im stoked about it. its on backburner though cus i plan on buying brake pads and stainless steel lines next week so i can finally do my rear disc swap
01 white GF
Discussion Starter #10
almost done with rear disc swap just have to rebleed the brakes tomorrow
since none of the bolts wanted to come off it inspired me to buy a air impact wrench which is now the coolest tool ive ever bought
01 white GF
Discussion Starter #11
so i took my car to a shop since it still wasnt working after a week of bleeding the brakes and had them do it. turns out the brakes were bled properly, the place i bought my brake pads sent me the wrong front pads, so they werent making contact with rotor and thats why it was mushy. so alot more money that it should have cost later, finally have my car back and a email to send
01 white GF
Discussion Starter #13
its actually pretty easy. i highly recommend an impact wrench though thats why it was as easy as it was. and making sure you get the right brake pads so your not stuck driving your moms jetta for a week and a half :unamused:
1996, Impreza, maroon, 2.2l, m
well I have other cars to drive, lol. I have an air impact but not sure if its high enough torque. Thanks.
1 - 20 of 696 Posts
