1 - 3 of 3 Posts
If whiteline "low" springs are only supposed to drop the car slightly over 1inch I should be fine to ride on stock struts for a 2000rs right? Anything more towards 1.5 and I would have to switch.
30mm = whiteline low springs which is just about 1"...
This ride height will be okay for the stock struts for a while.
I urge you to consider upgrading over time though as the stockers can't handle that kind of thing for long.
good luck
Jamie
www.subiegalracing.com
I decided I'll probably wait to put them on until I get new struts. I'll probably end up getting kyb agx's unless I can get a really good deal somewhere else. I found a set of four kyb's for $394.
1 - 3 of 3 Posts
