1 - 6 of 6 Posts
HI,
I have a 99 RS swapped with 02 USDM WRX engine. I recently noticed the brake booster vacuum hose used by the previous owner is a collapsed silicon aftermarket hose. Which is the correct OEM kit - the one for the 99 RS or 02 WRX?
Thanks!
98 impreza rs black 06 wrx swap
The rs one and the 06 wrx from my doner car both fit. Idk if the 02 would be any different. If you still have the rs booster I would try the rs one first. Also make sure you have the valve in the hose with a silicone hose or you’ll blow the booster when you get into boost.
WRX hose will have a check valve in it. You NEED the check valve. You can use any hose that fits, just make sure to have the check valve.
So I'm curious, when I +t'd my impreza, I never messed with the brake booster/hose. But I also never had any concerns with it, brakes always worked when I needed them to.
1 - 6 of 6 Posts
