1 - 20 of 29 Posts
GF OBS-T, GM RS EJ20, SF EJ20
What is the best 1/4 mile time for any STOCK LONG BLOCK (1.8, 2.2, 2.5 - NO opening the motor, NO low comp pistons, NO thick headgaskets, NO head swaps......) turbo/supercharged converted N/A Subaru motor.
I think the AVO kit runs in the low 14's to high 13's on stock longblocks.
1998 Subaru Impreza RS - RBP
So, what you are basically asking is:
What is the best 1/4 mile time with an RS-T that has not had internal work.
Correct?
Yeah, could also be a 1.8 or 2.2 just has to be STOCK High Compression LONG BLOCK.
I know a guy on here is pushing something like 11lbs on is stock longblock RS, but he hasn't taken it to a track. I'm sure his would be up there though.
I know a guy pushing 10lbs on a stock 2.2l, but that car has not been tracked yet either.....
02 F-150 Extended Cab
turboL ran 14's on his ej18 longblock w/ like 15 psi from a td04 i think ..or 10? i unno
1999 Subaru Impreza 2.5 rs-t
the one time i took my car to the track i ran a 14.1 with a kinda bad 60'. i probly could have broken into the 13's but i wanted to drive the car home after.
2001 Subaru 2.5 RS Silver
13.3 @ 101 from I believe RS_NW. I bought his turbo kit like 5 years ago...
2001 2.5RS-T BRP
I just went to the track for the first time a couple nights ago. My best run was 13.5 @ 101.5 W/1.89 60'.
My clutch is definitely not strong enough. It was slipping too much on the launch and between shifts. The stink in my car after a run was horrible.:barf:
Discussion Starter · #13 ·
I have a slipping WRX 3puc Exedy on my car now, not really looking forward to changing it :(
Discussion Starter · #16 ·
I hit the dragstrip last night & I'm pretty dam rusty on driving the OBS-t...
Car is a stock ej222 single port longblock with NO internal mods (like cams), stock ECU, running a TD05 @ only between 8-8.5 psi to avoid breaking down about 80 miles from home as I drove the wagon down to the track & back - about 80 miles each way. It was down about 41 GTHP from what it makes @ 11psi...lol...
I missed shifts on the first 2 runs resulting in a 14.052, & a 14.334 both with 1.8s 60' times... ? nerves, but I think the Sparcos I put in may require some getting used to on drag runs as the curve around my shoulders quite a bit.
SO
I figured I'd be slow & sure with the shifting on my LAST PASS & ran a 13.875 @ 96.96 MPH
Time slip read as follows:
1.849 60'
5.685 330'
8.804 1/8th mile @ 80.80 MPH
11.525 1000'
13.875 1/4 mile @ 96.96 MPH
I've run 8.6s 1/8th miles @ 82mph miles letting off early & coasting down from 84mph @ 10psi of boost ? what that would be on the 1/4 mile - I'm thinking about 13.4's
Has anyone run better than 13.874 1/4 mile on a stock ej222 + boost?
Discussion Starter · #18 ·
Ran the 1/4 in 13.31s @ 100.88 MPH - I can't shift from 4th-5th quickly...lol...
2001 gm6
Bringing this back up because your turbo 2.2 map based cars got me thinking about going this route. Did you upgrade the clutch since you were slipping?
1 - 20 of 29 Posts
