1 - 6 of 6 Posts
2000 Impreza OBS
My 2000 OBS has a bad exhaust leak and after taking a look, it seems the muffler has become entirely detached from the resonator; I'm assuming the bolts rusted off because New England.
So I am buying a replacement gasket, seems this Walker gasket will do the trick, but I don't know what hardware to use to bolt the flanges back together. I found this bolt kit but according to the diagram on the page, that's only for between the cat and the resonator.
So is there a special part I should be using, can I use the kit I linked, or should I grab some stainless steel nuts and bolts from Lowes- if so, recommendations on size?
Thanks!
00 BRP RS Coupe
You should be fine using 12mm or 14mm nuts and bolts in this area. The only special bolts needed in the exhaust piping is the spring-loaded ones at the cat...
2000 Impreza OBS
Discussion Starter #4
Thanks, I picked up some M12x1.25 nuts and bolts at Lowes since they fit the exhaust gasket holes. A little pricey to be honest, 10 bucks for two bolts and two nuts, but it saves me a trip to the dealer.
If anyone finds this in a search later, I believe the "proper" Subaru parts are 901660014 for the bolt and 902350001 for the nut, per Opposed Forces.
As for the flange being rusted out, I expect as much but I'm hoping there's enough there for me to get the gasket in and tighten that s***** up. Even if it's not perfect, I hope it'll do for now. Not keen on spending any more money than I have to on exhaust at the moment.
EZ GF w/Curves!
97'OBS/94'SVX LSi/00'OBS/01&#8
Next time to by a Ace or something. Get SS bolts and nuts. Should be less than like $2-3.
I kill threads!
That's where you just get some big ass washers to toss on there, so you can bolt it together.
1 - 6 of 6 Posts
