1 - 7 of 7 Posts
2002 2.5RS BRP
I'm replacing my timing belt and water pump in the very near future. I'm already getting a new oil seal, but is there anything else I need as far as gaskets or other seals involved in this job?
Timing belt, water pump, rear main seal, thermostat, coolant, a rocket ship, tensioner (optional), clutch and flywheel (optional).
2002 2.5RS BRP
timing belt? check.
water pump? check.
rear main seal (aka oil seal)? check.
thermostat? never heard I needed that..
coolant? check.
rocket ship? on backorder
isn't there a gasket for the water pump that I need?
95/99 Brighton STi
yes, there is a gasket, but I think it comes with the water pump.. just ask when you pick up the WP.
you're not pullin the motor when you do this, are you?
2002 2.5RS BRP
Discussion Starter · #6 ·
well I don't intend to pull the motor (to save time and money) because all my fluids are fine except the tranny fluid which I'm replacing anyway.
overdeveloped beater
Don't get a rear main seal if you aren't pulling the motor....get a front main seal.
Might as well get a tube of Permatex Ultra Grey so you can reseal the oil pump. You'll want to remove it and check the phillips screws for any that have backed out.
1 - 7 of 7 Posts
