1 - 4 of 4 Posts
1998 Subaru 2.5RS
Hi!
I have a connection to manufacturer pricing for EXEDY clutches only.
I will be running a V7 EJ207 on my stock RS Transmission until I can afford to pick up the 6spd swap. So I'm prepping to get parts around the motor before I purchase it.
My question is if anyone has experience with running a Exedy clutch kit with a similar setup of turbo motor + stock RS trans? If so which one? Please and thank you in advanced for your help!
2002 WRX
As was already mentioned, you have to match the clutch to the type of transmission you are using - push type with push type or pull type with pull type.
That said, best to buy once. Unless you are going to run the RS transmission for a long time before the 6MT swap, buy the clutch for the 6MT now and do it all in one shot.
Unless, of course, you have plenty of money to throw around and it doesn't matter to you.
1 - 4 of 4 Posts
