1 - 4 of 4 Posts
I've a 1997 v4 wrx none runner at the moment it's a work in progress I need to no what reading should each cylinder be is some any advice would be great guys thanks regards Nathan
Black 2001 RS
Depends on your compression ratio and elevation.
At sea level, atmospheric pressure is around 14.7 psi. If your engine is 10:1, I would expect compression readings around 147 psi.
If your engine is 8.5:1, I would expect 14.7*8.5 = 125 psi
At higher elevations, air pressure is lower, so you would get lower compression readings.
Denver is around 12 psi air pressure, so my RS at 10:1 would read around 120 psi.
'96 OBS
I'll just add that generally the important thing is that all 4 cylinders are relatively close in compression.
Banned
10% from the highest to lowest.
For the record, my motor which is a 257 bottom, 257 HG, and 251 heads are said to be around 8.5:1. I'm at sea level and I just recorded between 125 and 135 on my motor.
1 - 4 of 4 Posts
