1 - 8 of 8 Posts
2001 Subaru Impreza rs 2.5
Hey folks!
I have a 2001 Subaru Impreza RS 2.5.
It's a five speed manual all wheel drive.
The only thing I've done to it is intake and exhaust.
I think I have a water pump issue but I'm not sure.
I'll post a video on here shortly and see if it may be the valves.
I am hopeful it isn't that but I'm not sure until I
Attempt to fire it up.
If you have any suggestions please email me @
[email protected]
Or directly on here.
Thanks,
Jaymz
I kill threads!
Won't know anything with that video or at least a description of the issues.
I kill threads!
Car may or may not start. If it does start, it's going to be making a super loud ticking. May or may not idle, won't run right, sucks gas, a lot of symptoms.
Either way right now it's completely pointless for any of us to say what is or isn't wrong with the car, when you give us absolutely zero description of what your problem is.
Discussion Starter #5
Well I'll start at the beginning.
It started to overheat but only at an idle. If I revved up a little it would eventually come back down to temperature. So I figured it might be a sticking thermostat or a water pump. I looked at the timing belt and everything checked out. As of now I'm just trying to get the battery charged and fire it up.
That's where I'm at.
I kill threads!
I'd work in this order.
1. Check coolant level and top off. See if fixed.
2. Burp system, top off coolant. See if fixed.
3. Replace thermostat, fill coolant, burp system, top off coolant. See if fixed.
4. Replace water pump.
Now while checking coolant and stuff, make sure you don't see any oil in the coolant or coolant in the oil. Since it just overheats at idle, I doubt it's a blown headgasket, but might as well just look.
Edit:
I had this same issue with my car and it was nothing more than low coolant. When you went idle, the temps would skyrocket almost to the red. As soon as you started moving again, it'd drop right back down into normal ranges. I thought it was a thermostat issue, so I ordered one up, not even bothering to check coolant.
It only got worse after that, I started getting hesistation issues around 4500 rpm. Soon as I put in more coolant, all went away. Still got my new thermostat sitting in a box.
Discussion Starter #7
I'll do that. If I come across anything else I'll be sure to post it here.
00'RS/02' WRX stgEleventy
Low coolant... hear any water wooshing sounds when you rev the car?
1 - 8 of 8 Posts
