I am going to do a timing belt on my 1.8 and was wondering what water pump and thermostat anyone would recommend running. I don't want to end up with some cheap parts that will need to be replaced shortly after I install them.
Oem thermostat
Only change water pump if your having issues.
Actually you have to unbolt the elbow from the block.no reason to change it unless it binds up when it spins, or leaks somehow (highly unlikely). the thermostat is the important part and you dont have to remove anything from the car to replace it (except drain the coolant)
As far as tensioner goes do you think the Gates kit is well equiped?no reason to change it unless it binds up when it spins, or leaks somehow (highly unlikely). the thermostat is the important part and you dont have to remove anything from the car to replace it (except drain the coolant)
if you are going to replace things, get:
any water pump (its not a race car...)
OEM timing belt (or Gates)
OEM thermostat
OEM tensioner (costs $$$)
any idlers (theres only like 1 brand that makes them and they also supply OEM)
random OEM rubber parts and seals and grommets etc
