1 - 2 of 2 Posts
Ok so heres the deal. My subaru burns through coolant like crack. i have had to refill it 3 times in 2 months.
I think my heads are warped because when i have the ac on, i can smell coolant every once and a while. dont know if this relates to anything. The car doesnt show any leaks thats why i think is dumping in the engine.
Also the thermostat jumps up and down when i drive it for a while.
Could it be the thermostat or am i F*-ed and need new heads?
If so how much do they run?
2002 2.5TS
you should trial and error some things...change your thermostat first...its cheapest...
you getting any smoke on startup? if so what color is it? does it dissipate quickly? if so thats probably water evaporating = blown headgasket or yes warped heads...
when you do your oil changes does it look like a milkshake?
1 - 2 of 2 Posts
