ALL THIS SHIT IS LONG GONE. I AM keeping this thread up for price REFERENCE ONLY
Note: please dont email or ask for parts not listed.
I'm back from vacation, will answer all PM's in order received.
I've updated the prices and lowered most. Shipping is not included. Will consider all reasonable offers or trades.
All parts are from 2000, 1998, 1995 Imprezas.
Item Descripton Price
ENGINE STUFF:
1.8 L Subaru engine 75k miles, good compression $300.00
Panel Filter OEM almost brand new 8
Panel Filter OEM so-so condition 5
Panel Filter K&N almost (if not) brand new 20
Master clutch cylinder 1998 - under 15k $70
Slave clutch cylinder 1998 - under 15k $70
Master Brake cylinder (2k) 2001 - around 20k $70
Pressure Plate 2001 - 35k miles $80
Power Steering Pump 2001 - 35k miles $90
Power steering lines 95 or 98 $15
Subaru Oil Cooler JDM forester - Included turbo thermostat housing, thermostat, all hardware/hoses. Ran supercharger @ 6psi $101
Intake Manifold 1995 - 75k, All sensors included, partial fuel lines. T-body included. $65
Throttle body wiring harness perfect for early JDM swap $40
Fuel rails & injectors Side fed fuel rails. 1995 injectors - around 60k 60
Crank Pulley 2000 - 15k. Stock crank pulley. 12
muffler (2001 RS - 25-30k miles) 45
Intake Silencer 2001 - 15k $15
Hood Scoop backing plate 10
Intake elbow (Pass side air redirector) 5
Stock 2k intake tube with all silencer pieces 14
98 stock airbox 6
SUSPENSION STUFF:
Axles:
1 x Front axle from FWD auto (fits all impreza till 01 for sure - 75k miles) $45
2 x Awd front axles from AWD 2001 / 35k miles $70 (each)
Engine mounts 2000 - 15k. Left & Right 30 (both)
Tranny mount 2000 - 15k. 15
Front control arm bushings 2000 -15k. L & R. Perfect upgrade for pre 1999. 45
Rotors:
Rear rotors x 2 2001, under 15k $30 each
Rear rotors x 2 1998, 110k $15 each
Front Rotors x2 1998, 110k $15 each
Front Rotor 2001, under 15k (i think I have other one; cant find it right now) $30 each
Front Control Arms 00/01 - 35k. 70 each
Front Hubs 00/01 - 35k. 100 each
Front T-bone 00/01 - 35k. Good as a backup if you plan on modding yours for turbo manifold. 25
Rear trailing links one is 01 or 98; one with numbers is 00 $45 each.
Rear Swaybar /w all mounts (2k rs) 25
Rear Swaybar (98 rs) 10
Front Swaybar (2k rs) 10
Rack & Pinion 95 - 75k (aka: steering rack) 45
Rack & Pinion 2000 - 40k - one bent tie rod (aka: steering rack) 55
INTERIOR:
E-brake handle 2000 rs, black (with ebake cable splitter) 25
Front dash 2000 - under 30k, gauge cluster included, all wires, airbag, vents, top pocket..) $350
--can separate: dash alone - 250, gauge cluster 100
Lower driver side dash cover with foglight & cruise switches 35
Exhaust Heat Shield x 2 10
Alternator Cover (2k) 7
Steering wheel 2001 RS - red stitching + airbag. 110
Complete steering hub 2001 - everything from behind the wheel to steering column - /w Cruise control switch (can part). 100
Fuel line covers white ones that go under carpet and hold it in place. 5 each
Rear Diff guard stock 2k 8
Driver side mirror 2000 - Auto / electrical, Silver 60
Doorhandles (outside) 2000 - L & R - Silver. No scratches what so ever. 30 both
Lower steering wheel trim 01 7
Trunk lining x 3 Left & Right 20 both
Seat bolt covers 2 each
Seatbelt bolt covers (top) 2 each
ELECTRICAL:
2000 Complete wiring harness Completely uncut, headlight to tails. Comes with ECU (5sp), fusebox, JC torque chip spliced in ( 12 HP). 400
--2000 ECU 5-speed. Only if separated from harness 100
--JC Torque chip 12 hp. I think soobymods had dyno charts a while back. 100
--harness with out ecu / chip : 300
1995 Complete wiring harness Completely uncut, headlight to tails. Comes with ECU (4-auto), fusebox… etc. 200
1995 ECU (Auto) 4-auto. Only if separated from harness 50
Window Motor (2k) - side unknown 20
Door Locks - auto (2k) 15
Starter - Auto 95 auto - miles unknown. Either 75k or 10k. 40
Heater core (2k) 40
A/C fan / heater fan 40
Stereo:
Rear: Pioneer 4-way 200w 4 Ohm (TS-A6976) 30 both
Front: Pioneer 2-way 100w 4 Ohm (TS-A1385) 30 both
Pioneer 6-disk CD changer 70
Tweeter (2k) 12
Door Wiring harness with wiring for tweeters and power mirrors. 10
Shifter Linkage - 5 speed (2k) 40
Wiper motor - 2k rs 30
Wiper motor - '95 30
98 fog light 50 both
unknown year fog light 40 both
UNCATEGORIZED
Fuel evap canister - (aka: charcoal canister - 2k) with everything, including all hoses, mounting, sensors. 80
Spark plug wires:
95 - Bosch Ultra premium 7mm 30
98 - Packard 30
2000 - Magnacore KV-85 70
RX7 Turbo ii bits:
Secondary ignition coil 80
Distributor (not sure on correct name here) 80
NGK Spark plug wires R-8 70
ENGINE STUFF:
98 stock airbox 6
SUSPENSION STUFF:
Axles:
Rotors:
INTERIOR:
ELECTRICAL:
Heater core (2k) 40
Stereo:
Tweeter (2k) 12
UNCATEGORIZED
Spark plug wires:
98 - Packard 30
RX7 Turbo ii bits:
