So I got an RS that didnt run, i finally got it running, and it would run for a few seconds then stall out.
I pulled 3 codes, 1 for MAP sensor, and 2 for Atmosphere pressure sensor.
I replaced the MAP, and its still doing the same exact thing.
So now i think its a vacuum leak. How can i test this?
I noticed today that the car has a Throttle body spacer and that i cant see some of the gasket on the manifold side.... Would this be causing the car to stall out.
Smells like the car is running really rich..
The car stalls out right away when i let the clutch out in neutral.
heres a vid of the engine running.
http://www.youtube.com/watch?v=FQGPNPLsL6U
