1 - 3 of 3 Posts
2000 Impreza RS SILVER
Ok i just put my engine back together and in! I replaced the cluth and got a light weight flywheel. The cluth is a gripforce F1 cluth. My problem is that there is a flat spot when the the clutch pedal is letting out. I dunno if it is the slave cylinder or if the pressure plate it not putting pressure on the throw out bearing? It just seems like it is doing nothing half way down then it disengages and when you let out it almost stops coming out like there is nothing pushing it out.
thanks
yea i bleeded it a ton and got nothing but solid fluid. it was hard to pump because the pedal would stick somes times but if i start the car the cluth works, but with the flat spot.
1 - 3 of 3 Posts
