1 - 4 of 4 Posts
2000 Impreza RS SILVER
Ok i just put my engine back together and in! I replaced the cluth and got a light weight flywheel. The cluth is a gripforce F1 cluth. My problem is that there is a flat spot when the the clutch pedal is letting out. I dunno if it is the slave cylinder or if the pressure plate it not putting pressure on the throw out bearing? It just seems like it is doing nothing half way down then it disengages and when you let out it almost stops coming out like there is nothing pushing it out.
thanks
Sorry but i just spent the past 3 weekends building a brand new motor and it sux to put everything together and then have a problem like this i was hoping for a quick answer so i could make a decision. You have been helpful to me before and i was just wanting a quick answer and for someone to not be a prick.
1 - 4 of 4 Posts
