Have any of you used the two part foam stuff for filling body panels and your frame? I've picked up enough of it last night to fill the Subarus frame and the rocker panels on the car. I've used it in the past on a GTI-R and it worked really well. Now I'm just seeing if any of you have used it and what you thought of it.
Discussion Starter #4
Its two parts. It comes in seperate containers with one being the quick foam chemical and the other container being a hardening chemical. Once its hardened the only way to remove it from something is with a chisel or a power sander. You basically fill the hollow body panels with the foam to add rigidity to them. It cuts down on flexing in corners that you get from the stock frames or body panels.
