141 - 160 of 206 Posts
You did a really good job applying that tape.
Discussion Starter · #142 · (Edited)
I’ll post pics of progress here. Final verdict... dry ice doesn’t brake up the undercarriage undercoating.
The beat rush thing is cool.. I’m not gonna use any rivets just have it welded. Plus gotta take care of the busted oe sill lip
Last resort is scraping w fire & start wirewheeling seam areas
Discussion Starter · #144 · (Edited)
I did a thing. Found this mildly rusty 95 2.2 awd fully loaded, light in trunk and all, one owner with a super straight body, auto & 230k on the clock for $1350.
I got new bumpers & aluminum hood for the red build stay tuned.. thus.
all the extra body parts are going on this green boi. Tomorrow towing it to a friend that does body work at his own little shop. Quick respray, rust fix, face lift, and some maintenance and maybe I’ll sell her, or store her. Hm.
Discussion Starter · #146 ·
Found a defect in the OEM panels. Upon scraping..
The rear inner fender sheet metal to mid under chassis sill/floor stamps are totally different.
In the drivers side..
Passenger side.
I noticed its different since I spent 15 mins removing the OEM undercoating seam sealer in this crevice and looked at the other side.. and the metal is flush. No sealer or coating in between.. hmm
Discussion Starter · #152 · (Edited)
Interesting, the Rcm pickup is braced on the opposite side.
Also the manifold came w a bunch of heat “wrap” so covered all the coolent lines.. bc N O W A Y can I run an oil cooler sandwich plate. Maybe external oil filter adapter. Idk I’ll see what the temps are after it’s running.
If you deleted the built in oil warmer you would have no issue fitting a sandwich plate.
Discussion Starter · #154 ·
So I’ve been pretty busy and stuff, but filled my time at my home garage to learn to weld. Gonna stitch the gc8 myself coz my welder friends are too busy and my cars in the middle of no where.
Been practice on 22 gauge and 18 gauge. Some of these here suck but I more or less got the hang of it. Went through 2 sheets of this 22 gauge and first time in 18. It’s soooo much easier on the thicker stuff. That said,
You guys know more or less the gauge of most floor, wheel well, and frame metal? I think maybe the floor could be 20-18.. but engine bay 18 and frame 16? Regardless it’s gonna be hell of a learning experience.. well this whole build has been.
Discussion Starter · #155 · (Edited)
Goin in hard 2020. Maybe 2022.
Uncar related:
Welded up some braces for my door. Re tacked this like 5 times to get the door gap just right.
Discussion Starter · #156 ·
Found bits of a race car’s carbon parts after a crash. Mocked up a front wide fender vent & rear side skirt attachments... front would require to bolt “carbon fender vent” to my fender brace, notch it a bit, and cut fender in half and use only top part of steel fender. Rear too.. see pics.. should I waste my time?
Discussion Starter · #157 · (Edited)
Well there’s that then...
I’m gonna grind some of the welds where I had to fill..... and gonna fill everything g w a ton of seam sealer. Should look fine.
Update:
Discussion Starter · #158 ·
Corona time over? Took a stroll to the garage.. haven’t been here in ages.
Installed the beatrush braces.. again this is now about the 8th time I’ve ever welded
Discussion Starter · #160 ·
Fixing some jdm nostalgia.. olddddd Cusco manifold. Reattached a bracket & fixed a crack/bend in one heat shield. This is going on the green machine.
