^ You could convert it to single turbo, although you'd be better off using a JDM ECU and harness from the counterpart single turbo motor from that particular generation. Example: EJ20H you'd use a G ECU; EJ20R you'd use a K ECU, etc. But by the time you did this and sourced out all the extra parts to convert it to single turbo, you've exceeded the cost of just buying a single turbo EJ20G or EJ20K right off the bat, which has either a 16G or some other 300WHP-capable turbo, the later generations getting IHI turbos.
You couldn't use a USDM ECU, at least not without extensive extensive extensive work, and I haven't heard yet of anyone being successful with this (A lot of questions get asked about this regarding getting these older OBDI motors to pass OBDII emissions).
Another thing I forgot to add to my post above was that back in the day when I was considering buying an L or Legacy, going RHD and swapping in one of the tt motors I looked at turbo upgrade kits that still retained a tt setup (Obviously the perk of doing this swap
), and the cheapest "kit" I saw was made by Power Enterprise IIRC, and it was something like $3400. Not really worth it, considering I think the primary turbo was only about the size of a VF30 or something like that. No GT30's here. And before you ask, you can't just slap on some larger IHI turbos, say VF22's or VF39's or what-have-you, because the flanges on the tt turbos are wayyy different. Sure you could probably chop up new flanges for the up pipe and down pipe, but again, single turbo is cheaper. And then, again, you get into tuning issues, as already stated.
However, I've driven a few cars with this particular swap and its very cool; much different than any single turbo-equipped Subaru I've driven. The key though was they were all RHD. But I like the feel of having that broad power band and seemingly no lag quite a bit! And out of the box they feel really quick, even in a heavier Legacy, which is one of the cars I got to drive. I'm in no way bashing these motors (If I bought another Subaru as a project I'd probably do this swap), but commenting on issues you will run into and the fact that single turbo is cheaper in the long run and what you'll likely swap to anyway in your quest for more power.
