Hey,
First post and, for the record, I did use the search function.
Car is a 2000 Impreza Outback Sport.
I came home from a snowboarding trip yesterday. On my way home the ABS light came on, but went off shortly after, then came on again right before I arrived home. Not sure if this is related at all, but thought the more information the better.
About two hours after I arrived home I went out for a smoke and noticed that some of the lights on my car were still illuminated. The front, rear and side turn signal indicators are all on, as is the in-dash light. However, only on the right (passenger) side of the car.
The left-hand (driver's) side turn signal still functions normally. However, when I engage the hazard button, all eight lights stay solid no-- no flashing whatsoever.
After a few minutes of fiddling with the hazard button and turn signal stalk, the right side began to function as normal. After no more than 30 seconds, the right side was once again full on.
I searched Google and RS25, yielding no exact matches. However, I have read that people have difficulty with turn signals not working at all-- and the solution is often replacing the turn signal relay. So, I found that beast stashed way up in the dash and disconnected it. The result? Well, my turn signals on the driver's side don't work, but the right side remains illuminated.
So I pulled the three exterior lights one-at-a-time, starting with the tail light. I unplugged each, and the others remained on each time.
I've also checked some of the fuses in the engine bay and in the dash.
I'm at a complete loss here, please help!
