1 - 2 of 2 Posts
96 Legacy
Rattling my brain about a few things here.
Doing a 2.35 (EJ22T) stroker with 2.0 WRX heads, WRX manifold and WRX wire merge from Iwire.
I know the fuel pump needs replaced. Does the whole assembly need to be replaced or can I just throw in a WRX walbro 255lph? Was more so curious about the wiring aspect if it does need replaced.
92 TW 97 OBX
Wrx swap
You can just swap the walbro pump in. Make sure all the wiring you come across is perfect. Leave the wiring under the back seat exposed if you will be running wiring to the wrx fpc.
1 - 2 of 2 Posts
