Here you can see the problem...
At least...that's what the pic looks like anyway.Graham said:James, ok, with the intercooler mounted (RalliSpec TMIC) the intake outlet (in the picture, the whole with the red cap pointing straight at you) for the turbo interferes with the bottom left part of the intercooler, i.e the outlet hits the wall of the I/C.
What I need to know is if I can clock this turbo so that instead of pointing straight at the intercooler as it is now, it will point straight upward, allowing room for a charge pipe to be made. As of right now, there is absolutely no room for the charge pipe, so I have to figure this out.
Again, my question is if the turbo can be clocked, and I need to know if the wastegate actuator line will be in the way, or not allow the turbo to be clocked.
Graham
