1 - 20 of 26 Posts
Banned
One in stock for 200 shipped.
This is a Tsudo catted 200 metallic pipe.
This will fit OEM ,Tsudo, borla or replica ebay borla headers.
Its compatible with Stock OEM or Tsudo aftermarket Cat-back exhaust
Note: This test pipe removes stock OEM catalytic converter, with a 200 cell metallic high flow cat which might trigger a CEL (check engine light)
Downpipe outlet is 63mm
Manufactured from T304 / SUS304 stainless steel for durability and high corrosion resistance.
CNC cut flanges and fully TIG welded construction.
Less welds and bent than the competition for less turbulence and more flow.
Significant weight reduction compared to OEM exhaust system.
Utilizes factory 02 sensor position
Free straight check mechanical check engine light fix is included.
Easy bolt-on installation with typical hand tools, no welding or cutting required
Please note: This item may cause check engine light to come on. It is not meant to be use on vehicle that is street use.
2001 Impreza Outback Sport
great!!! when my HFC from ms3 customs / supers gives up Ill def grab this one! the price is what i paid for mine all beat up and used! wow
98 impreza outback
I bought same one from ebay and I love the sound of it! makes it so quiet on start up and idle and also just cruising around but when you get into it boy does it rumble!
2000 Impreza 2.5RS BRP Coupe
Son of a... I was just placing my order when i saw "sold out" again! Gah!
Banned
Discussion Starter #17
Are the flanges on the intermittent pipes for an 06/07 2.5i different from that of an 02-05 intermittent pipe? I did a test fit yesterday and the flanges are completely off.... I even tried a wrx/sti intermittent pipe... It was closer, but still off.
Sorry we never test fitted on a 2006 up Impreza.
Can I go ahead and place an order and pay for it while its on back order? Do you know when the next shipment will arrive?
Back order for another 2 months so we are not accepting pre orders yet.
98 impreza outback
Back order for another 2 months so we are not accepting pre orders yet.[/QUOTE]
Do you have any catless pipes yet?
1 - 20 of 26 Posts
