(on a '98 DOHC) so get this: i changed the cam oil seals (all 4) and crank oil seals, water pump and timing belt today. i re-did the timing belt several times and the same result; the crank line lines up with the block, the passenger side cams line up with each other and the marks on the block, the lines on the timing belt line up with all the marks on all the sprocket (all 4 cams and crank) BUT the cam sprockets on the drivers side dont line up with one another by HALF a tooth. WTF!!!!!!!?????
ill add pics when i can find the cord for my camera.
