1 - 4 of 4 Posts
2000 2.5RSt
I have a turboed 2.5RS 2000. And it has a stock TB 16114AA830.
Recently, I noticed a loud sequel when approaching 15psi.
I smoke tested from the air filter side and found a leak out of TB's rod that holds the throttle plate.
See video (Ignore the BOV leak):
Throttle Body Leak MY00 2.5 RS - YouTube
I tried to understand if I can replace TB with 02-04 WRX TB, but it wasn't conclusive. Can I use my existing TPS and IACV ?
Easier would be to just replace this 19 yo gasket on the sides of the rod. But, I don't see it for sale separately anywhere.
Another option is to send this to be ported and hope they replace the gaskets. I was considering TechWorks in Calgary.
Any suggestions ?
Thanks.
You can not swap a WRX throttle body on. The pattern is different as well as the IACV. Also the WRX throttle body has a MAP sensor on it.
As far as seals, I know nothing.
2000 2.5RSt
So, I'd need the manifold also ?
Ok, thanks!
1 - 4 of 4 Posts
