1 - 12 of 12 Posts
MY99 GF4 EJ227 JDM 6spd
i've just found a site that has this. I dunno if you take your throttle body to them to do it or you buy a new throttle body.
here's their site! i dunno if anyone else knows this:confused:
Moto-R Throttle body
Cobb took the throttle body off his web site I wonder what that means.
Anyways the stock one is like 62 mm. Cobb enlarges it to 2mm. When I first heard that I was like that's it, 2mm is all you get for $269. But he knows what he's doing. Then I saw a Cobb throttle body boy was I enlightened.
Just wanted to share that with you guys.
Discussion Starter · #7 ·
t.rod said:
Here is what is says at the bottom - MOST WORK INCLUDING THROTTLE BODIES AND HEADS ARE ON EXCHANGE CORE ONLY
opps! i wasn't paying attention. hheeeeheehe now we know!:p
2001 Silverthorn Coupe
Make sure that is all they do if you are only worried about the bore being larger. Cobb for instance, trims down the shaft (???) that the throttle plate attatches to, in order to show the least frontal area to the air coming into the TB at WOT. Also knife edging the lip/edge of the TB where it connects to a pipe has had some positive results so I've heard. The sheer size doesn't get all the gain, its all the little things in the details that make it worth while.
Greg
Why don't you guys lighten up? Explain the reason behind the mod then tell why it doen't help until a certain point, then how it helps. Not just repeting the same garbage. This is a new club, not the i-Club, the only thing your post is missing is "do a search", shutting down mods with no reasons is frankly for people who do not know what they are talking about, and just relaying garbage that they read someplace else. I doubt that you are those kind of people, so kick it up a notch.
I don't believe that the TB being bored in and of itself is that great of a mod either. Like I said most places do more than simply bore the TB and put a bigger throttle butterfly in place. You can do the same mods yourself, but not make the TB bore anybigger and raise the effeciency of your engine in the process. It will not put a kick in your pants when you do it, but all the little mods that "don't do anything" when added together are what makes a good engine package.
Calculate how much air is going through your TB by taking your engine displacement and finding how fast the air is traveling through it. By reducing the turbulance of the throttle plate in the middle of the TB opening, by making the cross section smaller, and the "lip" of the TB a smooth transition from the attached pipe into the TB, airflow will be smoother and more efficient. Think velocity stack, smooth airflow, fluid airflow.
Don't expect to gain alot of HP from the mod. Remember your engine is a system, with all the parts working together, increasing the effeciency of the parts of the system that you can without alot of trouble, will all add up.
Greg
i thought my reply was simple and explained why you shouldnt bother. you dont flow enough CFM with the "average" kit to take advantage of a bored out TB.
if my calculations are right you wont see benefits until around 12+psi (depending on turbo of course).
1 - 12 of 12 Posts
