Subies do not have lifetime fluid in them.. ask the guy that picked up a 200k forester that likely had the stock charge in it..yay..
It doesnt break down nearly as fast as engine oil but it does break down..
My suggestion would be Subaru Extra-S in the trans and rear diff.. order 5qts (from fred beans for instance) and youll have enough for both
For the record, the oil Fred Beans sells is NOT Extra-S it is the replacement...
there have been VOA done and posted on that "other" site and proved they are NOT the same!
Also Extra-S was made by some subsidiary of shell, the HPGO is made my idemitsu
Not to say the new "High Performance Gear Oil" shouldn't or can not be used but everyone seems to think it is Extra S!
Including myself up until a few days ago!
I bought some myself. Already used and didn't notice any problems.
I will continue to use it for my RS diffs but I am going to be buying Motul for the STi from now on.
My gearbox got frozen every single night over the winter...
Hoping Motul doesn't get too thick in cold temps..
Subaru Extra-S for me. It didn't change the feeling of the car at all really. Previous owner looks to have kept it decently clean. It should still be done though. 30k is the max IMO.
It'll save you time and headaches down the line and isn't that expensive.
Curious, where did you source your "Extra-S" From?
I can't seem to find the 5 gallon pails anymore...
subaru has super-seeded the Extra-S with the "HPGO" and it is now only available in QTs, the dealers receive them in cases of 12.
To the OP,
change your fluids!
it's fairly cheap and easy!
if you have 4eat, use the subaru ATF, maybe throw some trans tune in first before you change it and drive a day or two to clean things out
you will only be able to drain 4ish Qts out of the pan, most like to drain and filll, then do another drain and fill at the same time as there next 2 oil changes as there are 12qts total so 3 drain and fills, should roughly mean you have all new fluid, you will still have some old stuff left in there tho
use 75-90 gear oil for front + rear diffs if they are not LSD
I would buy the "HPGO" from fred beans, or cough up the extra cash for Motul.
If you have LSD rear, I thikn fred beans also sells a Subaru LSD oil or once again you can get Motul
you need 2 qts total for F+R diffs but buy 3 in case you spill some!
If you have 5mt,
front diff is one unit with 5mt so you need roughly 4-5 qts I think, look it up
use 75-90, same options as above...
lots of 5mt owners say the 5spd really likes it's syncromesh, most say a 1/2qt mixed in is enough!
Ok hope that helped!
NOW CHANGE THE FLUIDS!
EDIT: WOW this was posted 3 years ago! EFF ME!
