81 - 100 of 244 Posts
Discussion Starter #83
i've been known to be able to melt two pieces of metal together.
but i do not need all the extra rigidness with the crap roads of PA
Discussion Starter #85
got the bushing in the aluminum control arms, but they are going to wait to go in until i get my ball joint puller from snapon.
then while i have everything apart on the front i'll also install the 4 pot calipers
mounted the 225/55/16 on the goldies that i got from Sean 2 years ago and installed on the car. i need to install a small spacer on the rears because they rub just a tad.
but i do like the way they fill the wheel wells.
then i dunno why i waited so long to purchase jdm seats, OMG these things are so comfy.
Discussion Starter #87
look what followed me home last night:
yep bilstein pss9, brand spanking new, picked up for a very very good price
Discussion Starter #90
i read bilstein are good over all, even for dding
their spring rates are pretty good 405 and 255.
with the new poly bushings isn't going to help with the ride either but i still installed them.
Baby❤Daddy
98L Wagon
i'm sure it's different on different chassies..or how ever the hell you spell that. i've only ridden on them in an Abarth. over shiit roads..you have to hold your butthole closed or you'll poop all over the seats. on good roads..they ride like glass.
Discussion Starter #92
Some plastic surgery with a face lift done today.
yep, that is the bumper beam, well skin holder
bumper installed:
on the ground:
then i tried installing my control arms and i found out that they didn't fit. i didn't know there are a wide and narrow for the front bushing and well i got the wide probably made for the gd
Discussion Starter #94
the only issue is length of the sleeve for the front position bushing, is 61mm.
some models use a bushing with a sleeve length of 55mm.
that is the issue i had, you will need to measure it out.
i got the prothane bushings and they had the wider ones, i need to order the whiteline bushings
Discussion Starter #97
they are the one piece bushings. not the two piece.
if i can get them out without destroying them (aka no getting annoyed), i'll let you know.
i still have the turbo inlet if interested
Discussion Starter #100
catch up time, been way to busy with it being nice outside to play on the computer.
aluminum control arm install after i got the correct front bushing installed, with new ball joints and kartboy end links.
Also decided to install the subaru 4 pots and kick out those tiny single piston brake calipers.
a big woops on my part, don't forget to check to make sure your brake lines are not rubbing on anything or you can end up with this:
