1 - 4 of 4 Posts
ok, so i'm about to purchase a set of STI TGVs.... i'm going to put them on my wrx swap.. going to do the delete and port them... but here is my question.. they are the same as the wrx ones correct? my guess would be yes... but i'm not 100% sure.. does anyone know?
faster than yours.
STi MY04-06 uses a side feed injector setup.
WRX MY02-05 uses a top feed injector setup.
Depending on what year the WRX is, they are NOT the same. If your WRX donor for your swap is '06+ then you can use 04-06 STi TGVs.
1 - 4 of 4 Posts
