1221 - 1240 of 1748 Posts
Experimenter
Tubaru Pickup
Discussion Starter #1,221
Cables are fine, he was referring to your mounts to the wing.
Then again he doesn't weld in pajama pants ;)
oh, i used the eye bolts so i can tighten the cable. Turned out though (1) 2" long eye bolt is more than enough to tighten cable
gonna redo it anyway. the battle aero wing min spacing is 43" so i need to straighten stands and redo cables
Turbo, LS swapped Impreza RS
Cables hold large buildings taught like that, it should be plenty. Rule of thumb, functional wings should be able to support half the weight of the car.
Experimenter
Tubaru Pickup
Discussion Starter #1,223
So shorter 05-06 impreza rs axles we're the cure. Much smoother travel and turning now. And 34 degrees is awesome for boost, like break em all loose in 3rd awesome
