pretty much just me picturing it in my head holding up a finger for every 5' i thought i'd need then adding it all together on the same thought train. There will be very poor planning and a lot of flying by the seat of my pants. I'll need two fire extingushers for the flaming, one for the fact i'm using erw, and two for my no fucks given approach to building it a stick at a time using more of my eye to measure than an actual square table and tape measure.
make that 3 extingushers. Im goign to flux core most of it lol. Pretty much casue my cwi said i had the same level of pentration as the tig sample and because its WAY easier
used a carbide die grinder to perfectly match the die to the pipe. Its a pipe size die but it wasnt a nice fit. It was high in seat and would oval the pipe that lead to the kinking. Once i fit the die to the pipe it worked much better. I can probably get even better results if the pipe wasnt freezing cold too.
im extangerating a little with this sketch but you can see where it was high, once i ground that out, the die made a good 170° or so of contact and stopped the kinking
i could probably throw some weld on the inside sides of the die to keep the pipe from ovaling at all, that should make a much more "mandrel" type bend but then i'd probably have to beat the die off the pipe after each bend. Its not bad enough to go there yet.
After seeing your thread mounting gas pedal, I put a lot of thought into how I was gonna try and mount mine easily. Figured on this why fix what ain't broke
It'll be welded in between 3/4" pipe andshould actually be stiffer than the angle frame version. I was having a hard time welding the forester sheet metal. it was too thin, would burn away before i got any penetration into the angle
HAPPY THANKSGIVING DAY
My Goals:
ID Vehicle: To simplify repairs/fixes/etc I'd love to know the cars history.
Main focus: handling, functionality, reliability.
End goal, yes the beaten horse "22b" exterior styling.
Technical Research (I'll post all my reading/research material links here)...
Picking this up today!
v4 STi Ej20k swapped
4.44 5MT w/ LSD Rear Diff
v1-4 JDM Front Bumper
v5-6 JDM Aluminum Hood
v4 STi 4/1 Pots
Plenty of other goodies!!
She’s got some quarter rust which may get addressed at some point. She’s needs a heart transplant and I already have a 65k Ej20k...
Hey guys, figured I would post up some pictures of my swap as i'm coming to the turning point where I start putting it all back together again.
I should have been logging everything in order as I went but here is a photo dump to browse through
Exterior looks - This is how the car looks when I...
------Most Recent Picture------
So, this is my second RS. Not much else to say. All of the info from my first RS can be found here:
Equinox's Impreza 2.5 RS - Crashed - Subaru Impreza GC8 & RS Forum & Community: RS25.com
So. On with it.
This is my 1998 Impreza RS in Rally Blue Pearl. Look...
