401 - 420 of 1743 Posts
Experimenter
Tubaru Pickup
Discussion Starter #404
Did the windsheild frame this morning. Got it about finished, still needs the waves from welding straightened back out. At first I just had it all stitch welded but the went back and fully welded bottom to keep and moisture from running down glass and back into electronics area.
Experimenter
Tubaru Pickup
Discussion Starter #406 (Edited)
Nice!
Time to loose the perforated stuff :lol:
<3
This perfs for you.
Got a few things done. The rest of perf cut, mounted other lower control arm holes, mounted steering wheel, mounted upper pedal box supports, mounted ebrake lever, added a few more triangulation tube. Need to go after market on re sway bar mounts. The stick C is too tall and the mounts arent working out either
Experimenter
Tubaru Pickup
Discussion Starter #408
Turbo, LS swapped Impreza RS
I had to special order metric heims from the U.K.
Experimenter
Tubaru Pickup
Discussion Starter #417
Gonna check McMaster. No where local is gonna have heims
Joints gotta have a lil strength to it, gonna be pushing up on alternator and a hair off camber
Experimenter
Tubaru Pickup
Discussion Starter #419
We have ace, homedeopt, Lowe's etc. Don't remember of the selling heims though. Found endlinks so far, just need to remember what the female sleeve is called
