341 - 360 of 1748 Posts
Experimenter
Tubaru Pickup
Discussion Starter #349
Lil front end work now that flu is in the past. This phone (lgv30) has a weird wide-angle lens so anything close looks bigger, and since I'm in tiny garage, it looks better in person ;)
Experimenter
Tubaru Pickup
Discussion Starter #356
Would a turbo version give you more room or less? The one where the inlet is in the middle more.
I was avoiding the turbo version for two reasons. One, I figured the center inlet would interfere with my reversed manifold. And two, I dont have the upper reservoir tank so i didnt need the extra nipple on the radiator.
But now that i flipped manifold back i could use the center inlet rad but not sure if alternator belt will clear since i've really reduced the space there.
Baby❤Daddy
98L Wagon
are you going to put the alt back in it's OE location? and do you know the size of the belt need for it? iirc it was a 27. but i really can't remember exactly, and i can't find the thread where it's talked about for the people that have deleted their power steering.
Experimenter
Tubaru Pickup
Discussion Starter #358
yup, i used to run the alternator by itself in the middle. Though i had pic with the belt number but cant find it, but im pretty sure that ultra low mileage belt is in the garage of the belt hook. Pat i discussed it a while back, pretty sure its in his eg33 impreza thread
http://www.rs25.com/forums/f145/3346360-post592.html
Experimenter
Tubaru Pickup
Discussion Starter #360 (Edited)
Gotcha on the rad. Talking out of my ass, was the same gen Legacy rad any different? I would assume the mounting points on bottom would match. Plus I know you may be looking for a replacement... :[
They got an oe 06 for $40 too so I'm not too worried about. Differences seem to be subtle, like direction of slush box cooler nipples and stuff. The fan I have for it fits 03-08 so that's my range.
Side note, made a paper template for hood. Tried drawing mine from measurements but I missed a couple triangle dimensions, plus all the corners are radiusessi's, I didn't wanna waste a sheet of aluminum. It's not the prettiest template but it should get me into old land rover body gap range which is good enough for me.
10.5 x 54 x 47
