241 - 260 of 1748 Posts
Turbo, LS swapped Impreza RS
The weight of the mesh versus paneling is a good idea, although I personally would think aluminum sheet would be more appealing to the eye.
Experimenter
Tubaru Pickup
Discussion Starter #246
I think it will look good once its all white. Thats stainless perf so i dont have to worry about getting good paint coverage in all the lil holes. Aluminum would be nice but its a little harder for me to get without buying and i cant weld it to the steel.
I ordered 100 of these yesterday to mount the translucent white acylic sheets into the door bar areas and that bigger triangle behind door
got the ones with 3/8 holes
#32
95 Coupe, 95 Sedan & 95 Wagon
I have a ton of those left over from window net kits LOL
You get 4 and only use 2. Tabs that is.
And no Mr George, not post whoring this time :lol:
Just being a real e-dick and saying it's not pleasant looking IMO only.
With good criticism comes the bad haha.
Still a A+++ project :D
Experimenter
Tubaru Pickup
Discussion Starter #249 (Edited)
Beds framed, came out better than I thought. I grabbed some old 1/2" round bar, heated them up with tig and bent them into 90's. Then used them to make lil trusses to support the angles better. I could put the last two braces in the rear window area but I think I'm done for today.
Are you stripping the whole side teeth or at the arbor? Once I started using cutting oil I never stripped any teeth, and to combat stripping the Arbor I would put two Mig tacks between the adapter and the hole saw just to take up some load.
Experimenter
Tubaru Pickup
Discussion Starter #252
Stripping arbor. It was my fault I forgot washer again. Without washer the arbor only get 2 of the 3 teeth. I picked up a Milwaukee hole dozer hole saw and its holding teeth way better than the dewalts, it still has them all actually after this weekend's progress. Now it's welded to shaft now since arbor stripped. Did a lot of 60 degree cuts too, those are real hard on it since it use so much projection.
Bue you misspelled CNC laser cutter.
Terry: 50°+ always suck to do with a hole saw notcher. I use paper templates and an angle grinder for those extreme notches.
Experimenter
Tubaru Pickup
Discussion Starter #258
If I took my time on the 3D sketch I could have used a tube laser. I could actually remeasure the frame, adjust my sketch, big a jig table and mass produce these like an 818
