I've yet seen a cage fail directly because of it being ERW. It's generally incorrect nodes.
There's plenty of meat in the subframe to cut out to make room for a rotated rack.Played around with my steering u joint last for another hour trying to get the rough spot out. Just gonna have to live with it I guess untill I build my own cross member that let's me rotate the rack down a little to take some angle out. Drawback of lowering everything down into racecar position
as it sits i have 0 travel. Hoping coilovers will fix that with shorter strut bodies. Then I can try differnet spring ratesDo you have much susp travel?
