1 - 11 of 11 Posts
Two Mini Coopers!
Now check this out!!! KFP is extending a TEN PERCENT DISCOUNT to anyone who calls 1-888-518-6656 and mentions RS25.com for these pads. P/N's 721 (Front) normally $114.00 and 770 (Rear) normally $80.00, in #4211 Blue Compound.
Click here for the review I went off of at SubaruReview.com:
http://www.subarureview.com/showreview.php?id=395
-RS25.com
Leg 3.6R, FXT, XV, BRZ
These pads are awesome! That is my review at subarureview.com...the pads are still holding up well, if I had one complaint it would be regarding the squeaking when the brakes are cold & when there is a lot of brake dust built up. But the decreased stopping distances are amazing and worht putting up with the noise. If you want a pad that is not quite as noisy I believe the Silver compound has less dust & squeal but aren't quite as grippy, still grippier than stock, but not as grippy as their blue compound. If you have questions give them a call and ask, they have several different compounds availible to fit what ever your needs may be.
G
I'll have to keep them in mind when I need to replace my pads. :)
Not going out to replace pads for a 10% discount, you know.
Two Mini Coopers!
Mine arrived today, and in much better shape that the struts I ordered from Tirerack.com. These actually looked like they were packaged with CARE!
Two Mini Coopers!
Discussion Starter · #9 ·
These things grip so hard my ABS kicks in on dry pavement! I am still amazed at how much stopping power they give me. It's unreal... I'm loving it! Heh! :D
G
Somebody on the i-club posted that these pads ate away like 3mm of rotor in like 250 miles. :rolleyes:
Let us know how the rotors hold up there James. :)
1 - 11 of 11 Posts
